Activity Forums VEGAS Pro Audio Mixing
  • Audio Mixing
    Posted by Simon Bennett on March 4, 2007 at 12:19 am
    Hi I am a learner user of the vegas 6 editing software, I am having trouble getting my audio mixing to preview at all in the time line. The Project I am working on is a simple two tracks, 1 being attached to the d/v footage and 2 a sound track. I have bused them onto the mixer and can alter the track volumes as should occur but thats about it. Cant seem to find anyway of reviewing what ive done. I have the Revealed Offical Guide by saahlin) but cant seem to work this one out.
    Sorry about the lack of good jargon as I am just entering this new world in a self taught manner.
    Prob somthing simple Im doin wrong. Oh ive tried rendering a portion of the project to see if that works without success
    cheers simon
    Gary Kleiner replied 19 years, 6 months ago 3 Members · 3 Replies
  • Gary Kleiner
    March 4, 2007 at 7:13 am
    To create your audio mix use envelopes.
    Select the audio track and hit v and you will see a blue line appear across the center of the track. Double-click on the blue line and you can drag the point that appears that to adjust the volume. Add more points to keep adjusting.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Kim Nance
    March 6, 2007 at 1:53 am
    Hi Gary
    Thanks – V is cetainly quicker than the method I’ve been using – Insert/Audio envelopes/Volume. Which leads me to ask, why have we got two ways of doing the same thing? V and shift-V both add a volume envelope. It gets even more confusing when you look at the Cutomize Keyboard list.
    shift-V is listed as Insert/Envelope/TrackVolume.
    V is listed as View/Envelope/Track volume.
    But if you select, via the top menu bar, View/Audio Envelopes/Track volume, you find instead of adding an envelope to the selected track, you are globally turning envelopes on or off.
    Am I missing something?
    Regards
    Kim Nance
    Armadillo Post
    Melbourne, Australia
  • Gary Kleiner
    March 6, 2007 at 2:49 pm
    There’s an important difference between V and Shift/V.
    V will toggle the envelopes on an off being seen on the timeline. Shift/V will also toggle, but wil delete all your points!
    Gary Kleiner
