Activity › Forums › Adobe Premiere Pro › Audio Mix will not save
  • Audio Mix will not save
    Posted by Brieana Jennings on February 5, 2008 at 3:44 pm
    Hello,
    I’m new to PPCS3 and in the process of editing a hour documentary. I have 2 problems.Every time I open my project my audio mix key frames are gone and I have to remix it again. This also happens when I render the full timeline This is now very time consuming. Is this a bug or is PP not intended for long form projects.
    My second problem is when I nest a rendered timeline into another I have to render again. Can I render a timeline and then import it as one long clip or do I have to export it as a QT and then import it again.
    Please Help
    Brieana
    Steven L. gotz replied 18 years, 7 months ago 2 Members · 1 Reply
  • Steven L. gotz
    February 5, 2008 at 8:34 pm
    As for your audio keyframes, are you certain your cache files are on a drive that always gets the same drive letter?
    As for rendering a sequence, the render does not carry over when you nest that sequence into another. Exporting to the same codec as the project would be one solution. QT is seldom the solution on a PC.
    Steven
    https://www.stevengotz.com
