Activity › Forums › Apple Final Cut Pro Legacy › Audio Mix Question
  • Audio Mix Question
    Posted by Andy Permar on November 19, 2006 at 3:30 pm
    I’m mixing a show and have several pieces of identical audio on two tracks — all the music beds are on two tracks as is some nat sound. How do I lock the similar tracks together so I can obtain the same mix and get the same keyframes without having to go through the mix twice. I’ve tried everything but can’t seem to figure this out. It has to be simple though.
    Andy
    Jimr replied 19 years, 10 months ago 3 Members · 2 Replies
  • John Fishback
    November 19, 2006 at 4:09 pm
    I’m not clear how you want to use these tracks again. Is it a different section of your show or an ntire re-mix? If it’s just to use them again x minutes later or in a different sequence, why not copy and paste?
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.8 QT7.1.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.0.4, DVDSP4.0.2, Comp2.0.1, STP1.0.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    Pro Tools HD, Yamaha DM1000, Genelec Monitors, ISDN
  • Jimr
    November 20, 2006 at 4:06 pm
    Not sure exactly what you are asking here but I’ll give it a try.
    If you mean you have to mono tracks of the same audio and you need to link them together
    Just highlite the two clips and then hit ‘apple-L’ to Link together
    or highlite both clips then hit ‘option-L’ to make clips Stereo
    That way when you Mix Down keyframes will go to both left and right of Clips
    Hope that Helps, if Im understanding your Question right?
    Thanx,
    JimR
