Activity › Forums › Apple Final Cut Pro Legacy › Audio mix issues
  • Audio mix issues
    Posted by Andre Morton on January 16, 2007 at 10:10 pm
    Sorry to repost, but i’m still having touble with FCP 5.0.4’s audio mixer. I’m trying Mix / Key frame in real time using the mixer and the faders work on part of the clip and don’t on others. The actual signal input display will dissappear. The only way I’ve gotten it to reaapear is by undoing any associated render files which thusly hinders playback. Further suggestions? The audio files are aiff files, and i’m using alot of tracks.
    Andre Morton replied 19 years, 8 months ago 2 Members · 2 Replies
  • Walter Biscardi
    January 16, 2007 at 10:30 pm
    [andre morton] “The audio files are aiff files, and i’m using alot of tracks.”
    Are they all converted to 48khz before you put them into FCP? If not, they should be.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Andre Morton
    January 16, 2007 at 11:35 pm
    Thank you kind sir, 48k, that seems to have done it!
