Activity Forums Adobe Premiere Pro Audio missing
  • Audio missing
    Posted by Ong Joseph on May 28, 2007 at 3:47 pm
    Hi all,
    I’m working on my showreel and I found out that one of my footages which is an .avi file does not have audio when I imported it into adobe premiere. However, when I did a normal playback on my windows media player, the audio was there. I checked out the properties and it stated “MPEG Layer-3” under the audio. Can anyone help? I really need the audio from my footage as I’m compiling my “editor” showreel. Would appreciate it very much if anyone could help.
    myx
    Ong Joseph replied 19 years, 3 months ago 2 Members · 4 Replies
  • Blast1
    May 28, 2007 at 7:04 pm
    [myx_motion] “I found out that one of my footages which is an .avi file does not have audio”
    What kind of .AVI, its a generic term for many formats.
    [myx_motion] ” I checked out the properties and it stated “MPEG Layer-3″ under the audio.”
    Is the footage you are trying to use DIVX?
  • Ong Joseph
    May 29, 2007 at 3:32 am
    Yes. It was created using DivX Compression. I extracted the video from a DVD. IS there any way I could get the audio to work in adobe premiere?
  • Blast1
    May 29, 2007 at 6:06 am
    [myx_motion] “Yes. It was created using DivX Compression.”
    Divx isn’t the best format for working in Ppro, interleaved with MP3 is very limited, I would search the net for a Divx to DV converter that will convert the MP3 to wav, then it will be easier to handle in premiere.
  • Ong Joseph
    May 29, 2007 at 1:45 pm
    Thanks. I think I’ve got it. Really appreciate your expertise..
