Activity Forums Apple Final Cut Pro Legacy Audio mismatch after capture
  • Audio mismatch after capture
    Posted by Will Cox on April 30, 2009 at 10:33 pm
    Hi there,
    I have been having a problem capturing this footage that was shot. It was shot at standard def 24p and so I put the Easy Setup Format at NTSC and the Use at DV-NTSC 24p then captured using Capture Now. The problem that keeps occurring is the audio is off about 2-3 frames, anyone know what could be the problem?
    Will
    Will Cox replied 17 years, 4 months ago 2 Members · 2 Replies
  • Simon Redmile
    May 1, 2009 at 9:45 am
    Have you checked your frame offset?
    Cheers,
    Si
  • Will Cox
    May 1, 2009 at 5:42 pm
    Got it thank you.
