Activity Forums Apple Final Cut Pro Legacy audio meters in fcp
  • audio meters in fcp
    Posted by Tvmaninc on November 13, 2007 at 2:58 pm
    ‘ve been working on Discreet Logic’s Smoke for 8 years and am now using FCP more and more. One difference I can’t figure out is the audio metering. On other higher end systems you have markings for -10 db which is how most audio designers send there audio.
    On FCP you have -12 db. Is there anyway to change the meters or customize them?
    Also we normally put tone of -20 db on tape. FCP defaults to -12db. Why?
    Thanks.
    don
    Jerry Hofmann replied 18 years, 10 months ago 5 Members · 8 Replies
  • 8 Replies
  • Jerry Hofmann
    November 13, 2007 at 3:21 pm
    There’s not a way to change these meters… you can setup bars at any level… they don’t have to be -12 they can be whatever you set them to be.
    Jerry
  • Tvmaninc
    November 13, 2007 at 3:27 pm
    Thanks Jerry.
    Currently when we lay back to dig beta we’re having to adjust the audio levels on the deck. Would love to be able to do it from FCP.
    I guess I can run -10db tone and put a sharpie mark on my monitor!
  • Rick Sebeck
    November 13, 2007 at 3:32 pm
    Tools> Audio Meters
    This lets you adjust the master gain of the output.
  • Tvmaninc
    November 13, 2007 at 3:36 pm
    Yes, but no markings for -10db which is required when mastering to dig beta.
  • David Bogie
    November 13, 2007 at 5:44 pm
    [Dave LaRonde] “…which is why they put those little knobs on Beta decks. They adjust audio input level.”
    Cut it out, you’re killing me.
    bogiesan
  • Warren Eig
    November 13, 2007 at 8:52 pm
    Everything we do, or get from sound mixes (2.0 or 5.1) that we master to Digi-Beta is always -20db for tone at the bars. That seems to be industry standard her in Los Angeles.
    Warren
    Warren Eig
    O 310-470-0905
    C 310-560-6245
    email: warren@babyboompictures.com
    website: https://www.babyboompictures.com
    https://www.atomfilms.com/af/content/knitwits
    https://www.atomfilms.com/film/family_xmas.jsp
  • Tvmaninc
    November 13, 2007 at 8:56 pm
    I must not be explaining myself correctly, I just want to see a visual -10db on the FCP meter and not have to monitor it by going back to the tape room and adjusting levels on the deck.
  • Jerry Hofmann
    November 19, 2007 at 12:57 pm
    That is not possible. You are explaining yourself perfectly. There’s no way to do exactly what you’d like to do.. have to do it using master output and/or adjusting the audio input levels on the deck.
    Jerry
