Activity Forums Apple Final Cut Pro Legacy audio merge clips
  • audio merge clips
    Posted by Moztu on August 9, 2005 at 5:05 pm
    Hello guys!
    We have made several audio merge clips. We are using them in the timeline and would like to locate the source clips we used to make that merge clip. We can do that manually but is there a way to automatize that? or an easier way to do it?
    thanks a lot,
    miren
    Moztu replied 21 years ago 2 Members · 2 Replies
  • Andy Mees
    August 9, 2005 at 5:22 pm
    from Andrew Balis’ excellent tutorial “Getting the Most Out of Match Frame In Final Cut Pro HD” on kenstone.net
    (if you haven’t spent some quality time with the tutorials at kenstone.net you should really take a look)
    How to Match Frame From Subclips and Merged Clips
    When you Match Frame from subclips and synced or merged clips, your Match Frame options are extended.
    When you sync video and audio clips in FCP, and subsequently use the new merged clip in a sequence, you have two different Match Frame options. You can match back to the merged clip, or back to the original video and audio sources used to create the merged clip. In other words, you can go back to the “child” or “parent” clip. It’s the same with subclips. You can Match Frame back to a subclip, or back to the original source clip used to create the subclip. This is great when, for instance, you’re working with a subclip and want to find another portion of the same media used to create that subclip.
    To Match Frame back to the subclip or merged clip, the command is the same as a standard Match Frame:
    Press F
    or
    Match Frame button in Canvas
    or
    View menu > Match Frame > Master Clip
    To Match Frame back to the parent clip, do either:
    Command/Option/F
    or
    View menu > Match Frame > Source File
  • Moztu
    August 10, 2005 at 7:13 am
    thank you Andrew but i already knew that.
    i am looking for some way of making this process automatic, since i need the original name of the files for the audio postproduction. aparently the naming indicates the diferent mics, so we need to recover it for the audio technitian. i don
