Activity Forums Apple Final Cut Pro Legacy Audio Mastering or individual channels?
  • Audio Mastering or individual channels?
    Posted by Robbo Ando on June 29, 2009 at 2:27 am
    Hi, I was doing some audio mixing with the Final Cut audio mixer and I’ve come across some confusion.
    Is it better to modify the audio for 0dB’s on each individual track so that the voices are more audible on their own track – or is it best to modify the audio so that the Master is no more than 0dB’s.
    If say the speaking tracks are reaching 0dbs when I raise them, but the Master only altogether amounts to -12dBs should I then raise the voices audio so that it is peaking on the individual track, and at 0dBs on the Master feedback?
    https://www.thatsfishing.com.au
    https://www.jwsanders.com.au
    John Fishback replied 17 years, 2 months ago 2 Members · 1 Reply
  • John Fishback
    June 29, 2009 at 3:36 pm
    You should mix for the master – your final output. The peak and other levels may vary according to your delivery specs. If it’s for broadcast, get the delivery specs from the broadcaster. They may specify a dialog level, an average level and/or a peak level, For instance, dialog might be -20 with peaks not to exceed -10. But check with your client to be sure. If the delivery is for DVD, the specs will probably be different. If you have a dialog level specified, you should first adjust you dialog to conform to the spec. Then, add music and effects around the dialog so it remains audible.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
