Activity Forums Adobe After Effects Audio – Markers Trouble
  • Audio – Markers Trouble
    Posted by Frank Weber on September 20, 2007 at 1:49 pm
    I’ve always used the * button on the keypad to drop markers as a way of planning my timing while using Audio. But now in CS3, After Effects drops the marker 5-10 frames after I actually hit the Star button.
    Please help.
    I’m on Windows.
    Katherine Landgrebe replied 16 years, 10 months ago 4 Members · 8 Replies
  • 8 Replies
  • Steve Roberts
    September 20, 2007 at 2:18 pm
    Hm. Slow response.
    Got anything else running at the same time?
    Using MP3 audio?
  • Frank Weber
    September 20, 2007 at 2:32 pm
    Thanks. But no I don’t have anything else open. I’ve re-installed the audio driver and restarted everything.
    When I switch off the audio layer (Wav or Uif) it works fine.
    I’m running Dual-Duo-core 3gig processors and 4 gigs of ram with a good audio card so there shouldn’t be any problems???
  • Steve Roberts
    September 20, 2007 at 2:49 pm
    If you have the audio waveform showing, can you hide it?
  • Frank Weber
    September 20, 2007 at 2:58 pm
    The Waveform is not showing – It’s instantanious when I do a Video preview, or an audio preview. But not both ( Normal Ram Preview.)
  • Steve Roberts
    September 20, 2007 at 3:17 pm
    Hm. Maybe it’s a bug. You can write to aebugs@Adobe.com .
    Until then, you might have to just do Audio-only or Video-only previews when setting markers. I’d use Audio-only when marking hits in the music, but looking at the waveform can be more accurate sometimes. Sorry.
    Anybody else?
  • Frank Weber
    September 20, 2007 at 4:37 pm
    Thanks Dave! Thanks Steve!
    I reckon it’s time I write to Adobe.
  • Johan Hoogendoorn
    September 20, 2007 at 9:28 pm
    yes it is!
    an annoying bug indeed
  • Katherine Landgrebe
    November 23, 2009 at 12:09 am
    And… is there a way to move all markers at the same time to the correct position to keep the relation?
