Activity Forums Apple Final Cut Pro Legacy Audio management in FCP7
  • Audio management in FCP7
    Posted by Oliver Parker on July 17, 2013 at 5:15 am
    Hello,
    I’m assembling a film a the moment in FCP7 and audio rushes are coming in with anything between 4-10 tracks of audio, but with the a stereo mix in A1 & A2. If I cut with just the stereo tracks, when I lock the cut and export the omf will the original full number tracks be there for the Sound post? If no is there a way around this?
    Ollie Parker
    Oliver Parker replied 13 years, 1 month ago 2 Members · 2 Replies
  • Nick Meyers
    July 17, 2013 at 6:46 am
    [Oliver Parker] ” If I cut with just the stereo tracks, when I lock the cut and export the omf will the original full number tracks be there for the Sound post?”
    no automatically, no.
    you can try cutting with just the mix,
    and at the end of the edit, you can do a pass where you match frame the audio (which SHOULD bring back all tracks into the viewer)
    and re-edit the full set of tracks back into the timeline.
    problem is this can go wrong. FCP can lose the lnk back to the original master clip.
    there was a long-ish thread about it a while back.
    2 other approaches to editing w the mix-down:
    1. you fix the problem:
    edit with the mix-down,
    use Sync n Link to re-conform a multitrack version in FCP prior to making the OMF or AAF
    2. sound fixes the problem:
    give sound dept AAF
    sound dept uses Synchro Arts Titan to re-conform in ProTools
    but you could (probably should) just edit with all the tracks,
    in which case you might not need a mix-down on A1+2
    nik
  • Oliver Parker
    July 17, 2013 at 6:53 am
    Thanks for the info, I guessed that would be the case. I think because of the crazy schedule, I will have to go with the last option and cut with all the tracks. Cheers Ollie
