Activity Forums Adobe Premiere Pro Audio link issue
  • Audio link issue
    Posted by Claudia Gabriela on June 25, 2015 at 7:46 pm
    Hey guys,
    So I’m working on Premiere Pro CC. I have a project where I imported multiple projects’ sequences into to create one big show.
    After doing this, I saw that on the bottom right it said “Conforming ____” For each of the mts files that were part of the projects I was importing. There was some sort of conform error, and now the audio is all screwed up on the ORIGINAL Premiere projects. The part where the audio screwed up is repeating over and over through the rest of the video file… I started these projects on an older version of CC and had to move to a newer computer with a newer version of CC. No, i cannot go back and work on the older version, as per my client.
    I’ve tried making the media go offline then relinking, emptying the media cache, and reimporting the file… but if i delete it, the clip disappears…..
    Is there any way to fix this issue? The original projects are all screwed up and I have no answer for my client as to how this happened or how I can even fix it.
    I’m working with C300 footage.
    Todd Dayton replied 10 years, 10 months ago 2 Members · 1 Reply
  • Todd Dayton
    October 26, 2015 at 9:51 pm
    Hi Claudia,
    Did you ever find a solution to this. I just encountered the same issue when migrating C100 footage from another system. The sequence is cut but the audio has the same relinking error you encountered.
    Thanks.
