Activity Forums Apple Final Cut Pro Legacy Audio levels?
  • Posted by Sverker Hahn on December 12, 2009 at 4:55 pm
    I am editing HD material to make a DVD. Thinking about audio, which levels are recommended? The footages are seascapes where one can hear waves and occasional birds. Using Audio Mixer and iMac, it seems that a level of -30 seems to good for this kind of background audio. If aiming to level 0 I have to change the settings too much, since the recorded level is quite low, even if I have had the max recording level on the camera. Or … ?
    Sverker Hahn, Stockholm
    Slower is better!
    Sony EX1
    Final Cut Studio 2
    iMac Intel
    MacBook Pro 15″
    Michael Gissing replied 16 years, 9 months ago 3 Members · 3 Replies
  • Greg Ondera
    December 12, 2009 at 6:46 pm
    Since the beginning of digital audio, no one can use 0 level as a standard, unlike analog audio. At a maximum -12db is acceptable when doing interviews, but -20db is what most pro audio guys record at so they have the headroom in case a loud noise makes the audio peak.
    Greg Ondera
    http://www.Plexus.tv
    http://www.SurgeonToday.org
  • Sverker Hahn
    December 13, 2009 at 11:13 am
    Hi, Greg,
    So I wasn´t completely wrong, then? I will start with your suggestion of -20.
    Thank you.
    Slower is better!
    Sony EX1
    Final Cut Studio 2
    iMac Intel
    MacBook Pro 15″
  • Michael Gissing
    December 13, 2009 at 9:45 pm
    Do you mean record levels in the field or post production levels?
    There are standards for post production broadcast levels which has been covered here a lot so a search of the forums will help. Even if you are making a DVD it would help to know what standard levels are so that your program has the right perceived loudness.
