Activity Forums Adobe Premiere Pro Audio levels
  • Audio levels
    Posted by Dave Rawson on December 29, 2012 at 10:27 pm
    Switched from Final Cut to Premiere. It’s strange to me that when adjusting audio levels on a track, it adjusts levels on all the rest of the clips sitting on the same track. I am familiar with adjusting volume levels withing the effect controls, but it seems limited.
    Is there a way, like in FCP, that you can adjust levels to single clip without impacting other clips on the same track?
    Gabriel Sanchez replied 13 years, 8 months ago 3 Members · 2 Replies
  • Angelo Lorenzo
    December 29, 2012 at 10:40 pm
    Well there a few ways of doing it within FCP, do you mean using the pen tool to create keyframe adjustments? or…?
    In terms of the keyframes/pen tool, Premiere works exactly the same.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Gabriel Sanchez
    December 30, 2012 at 12:55 am
    Using the audio mixer you change the Track levels, and this affects to all clip in this track. Changing individual Clip levels must be done in the volume effect in the control effects pannel or in the timeline using the clip´s yellow line. You can also change gain levels on individual clips right clicking them in the timeline and choosing Audio Gain.
    Regards
