Activity › Forums › Apple Final Cut Pro Legacy › Audio Levels question
  • Audio Levels question
    Posted by Subspecies on March 5, 2006 at 12:24 am
    hi all,
    i’ve got a 30 minute piece cut where the audio sounds fine, level look good…everything seems fine, yet when this piece is output to a DVD and played in a convention center, teh audio on the monitors or tv screens must be completely maxed out to hear the program….
    i thought maybe Compressor was messing with my levels, but it’s not…
    any ideas?
    Alexander Kallas replied 20 years, 7 months ago 4 Members · 4 Replies
  • Bouncing Account needs new email address
    March 5, 2006 at 1:07 am
    Give details of what level the FCP meters read (and if its just PEAKS or AVERAGE)?
  • Kerry Brown
    March 5, 2006 at 2:45 am
    What settings are you using in Compressor? Are you using AC3 audio (Dolby 2.0)? The settings in AC3 will affect the level of the audio comming off the DVD -12, 27, -31. -31 giving the louder output in AC3
    KB
  • Subspecies
    March 5, 2006 at 3:22 am
    i’ve used AC3 and the raw aif files….peaks are between -12 and -20
    most of the stuff was recoreded at a studio by professionals (which i’m not) and i haven’t messed with those levels at all….
  • Alexander Kallas
    March 5, 2006 at 11:32 am
    [dante pignetti] “‘ve used AC3 and the raw aif files….peaks are between -12 and -20
    After your are happy with your audio levels in FCP (listen to your time-line playing into a tv), you need to set your AC3 encoder to -31 dBFS, this preserves the audio levels set in FCP.
    Cheers
    Alexander
    Cheers
    Alexander
