Activity Forums AJA Video Systems Audio Levels Problem
  • Audio Levels Problem
    Posted by Ben Dittrich on August 28, 2006 at 2:23 pm
    Hey all.
    I’am using a Kona LHe on a G5 Quad, running Final Cut 5.1
    When i “edit to tape” i can control the Audio Output with the loudspeakers buttons on my keyboard…. but i want a prober output of 1kHz – 9db looked for the time while i’am printing to tape.
    In the system prefrences i’am using AJA Kona as Input and Output
    In Final Cut the “Output for edit to Tape” is the same as the “Playback Output”
    Do you guys got an idea what setups i have to make to get a clean Audio Output?
    Ben
    Bob Zelin replied 20 years ago 3 Members · 2 Replies
  • Jeremy Garchow
    August 28, 2006 at 4:36 pm
    Yes, don’t use your Kona for your internal system sounds as you have found your system volume will effect your output to tape. If you need sound out from other applications on your computer, simply hook up your G5 audio out to your mixer.
    Jeremy
  • Bob Zelin
    August 28, 2006 at 8:31 pm
    I agree – buy a cheap audio mixer – under $200 – for audio monitoring – it will work great, and do exactly what you want.
    Bob Zelin
