Activity Forums Avid Media Composer Audio levels on export from Adrenaline
  • Audio levels on export from Adrenaline
    Posted by Point&shoot on October 14, 2005 at 8:19 pm
    Using MC Adrenaline and here’s my flow:
    1) Finish 30 second spot
    2) Using File – Send to – to make a Quicktime reference .mov file and .wav file
    3) Open .mov file in Sorensen squeeze
    4) Create NTSC DVD Large mpeg file for client proofing from a ftp site. I upload spot they download from ftp.
    Now here’s my problem:
    Sometimes playing the end result mpeg file the audio is low. It’s fine on the meters in Adrenaline and on the outputs of Adrenaline. Any ideas??
    Jon Zanone replied 20 years, 11 months ago 2 Members · 1 Reply
  • Jon Zanone
    October 15, 2005 at 2:59 pm
    Try doing a mixdown of your audio(make sure you select stereo). Boost the audio level on the mixdown (I like using the audiosuite’s compression). Highlight only the mixdown and video tracks and export the higher level audio tracks. That way, you’ve got your normal level for output to tape, and a higher level for export.
    Or, you could normalize your audio in Sorenson to -1db….
    Jon
