Activity Forums Apple Final Cut Pro Audio Levels in a Compound Clip
  • Audio Levels in a Compound Clip
    Posted by Michael W. towe on May 1, 2014 at 10:48 pm
    Seeing something a bit odd and wondering if others are seeing it. I have a bunch on interviews that have each been edited, and each then turned into a compound clip. Compound clips will then be placed into a timeline and reordered as necessary.
    Inside the compound clip I have added a Voice Over Enhancement effect to the audio and set the compressor to average out at -20db. This all works fine inside the compound clip. However when I place that compound clip into a project/timeline the audio is now 4db less than in the compound clip. In other words I need to raise the audio levels on the timeline compound clip by +4db.
    What am I missing here? Shouldn’t the levels of the compound clip on the timeline be the same as the levels of the clips inside the compound clip?
    Thanks in advance,
    Michael W. Towe
    President M2 Digital Post
    http://www.m2digitalpost.com
    Michael Garber replied 12 years, 4 months ago 3 Members · 4 Replies
