Activity Forums Adobe Premiere Pro Audio Levels High when importing XML into Premiere Pro CS 5.5 from FCP 7
  • Audio Levels High when importing XML into Premiere Pro CS 5.5 from FCP 7
    Posted by Adam Berch on April 3, 2014 at 7:05 pm
    I use Final Cut Pro 7 for most of my Ediitng. I finish a job in Final Cut (mostly cuts, crossfades and Blur Dissolves) that is about 20 minutes. I export it out as an XML. I open up Premiere Pro CS 5.5, I import that XML file into Premiere and the project opens up fine ( I have to replace my Blur Dissolves with one in Premiere and I use Posterize Time to replace the Strobe Effect I use in FCP7) The only thing that confuses me is that the Audio Levels are much higher when I import it into Premiere. I usually have voice over music and when I import it into Premiere, I can hardly hear the voice. Why is this?
    Is there a way where I can import it into Premiere and all of the levels stay the same as it was in FCP 7? It really is a pain to have to go through all of the clips and re-do the Audio Levels.
    Any help would be appreciated.
    Thanks in Advance
    FCP 7
    Premiere Pro CS 5.5
    Mac Pro
    10GB RAM.
    Alex Udell replied 12 years, 5 months ago 2 Members · 3 Replies
  • Alex Udell
    April 4, 2014 at 2:41 am
    not sure audio mix is part of the XML spec….
    did any automation come thru?
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Adam Berch
    April 4, 2014 at 1:20 pm
    What do you mean by “did any automation come thru?
  • Alex Udell
    April 4, 2014 at 6:01 pm
    Was there reframing of audio levels done in FCP….that is also present in PPro?
    I you had done this…and that’s missing….it may be that XML doesn’t pass audio level data as part of its specification…
    Alex Udell
