Activity Forums Apple Final Cut Pro Legacy AUDIO levels for web
  • AUDIO levels for web
    Posted by Colleen Fitzgerald on July 19, 2009 at 2:40 pm
    Normally I edit on AVID and my audio is under -10 with peaks no hotter than -12.
    Is this the same on FCP? What about when your final output is for the Web. I feel like I’ve heard that for both web and DVD, you should mix hotter b/c the compression (?) lowers the audio. Is this true? And if so, what level to you suggest mixing to?
    Im very much a novice to FCP.
    John Fishback
    replied 17 years, 1 month ago
    2 Members · 1 Reply
  • John Fishback
    July 19, 2009 at 3:50 pm
    Your Avid guidelines are pretty much the same for FCP. For the web, I compress and normalize audio. The only concern I’d have is the levels of existing audio on the site. You want your audio to be consitent with that audio. This is why there are detailed audio specs for broadcast. If yours is the only audio being used, then max it.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
