Activity › Forums › Apple Final Cut Pro Legacy › audio levels for non-broadcast project
  • audio levels for non-broadcast project
    Posted by Scott Davis on May 1, 2006 at 9:32 pm
    I’m familiar with -12 or -20 db for broadcast for audio levels. What do you guys set you levels at (average level that is) for a non-broadcast, straight to DVD project. Its an exercise video with professionaly recorded VO and stock music as the majority of the audio.
    Scott Davis
    Matt Sandström replied 20 years, 5 months ago 3 Members · 2 Replies
  • John Fishback
    May 2, 2006 at 2:14 am
    You can look at this thread. If you search on this forum and the audio professionals forum you’ll find other discussions, too. https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=30&postid=855551
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.3 QT7.0.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.0.4, DVDSP4.0.2, Comp2.0.1, STP1.0.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors
  • Matt Sandström
    May 2, 2006 at 10:32 am
    i mix my masters to -20db with peaks at around -8, then bring this up to -12 and 0 respectively for festival screening copies, since you’ll be playing with films that haven’t been sound mixed at all and thus have a dynamic range from around -3 to 0 at best, which means projectionists always turn down the volume for the entire show. a similar strategy could certainly be used for non broadcast video copies.
    /matt
    https://www.mattias.nu/
