Activity Forums Apple Final Cut Pro Legacy Audio Levels FCP to QT
  • Audio Levels FCP to QT
    Posted by Michael Harrington on October 14, 2010 at 3:47 pm
    Wrapping up long-term huge project, 80-hr HDV footage digitized in ProRes422 for 2-hr DVD. I’m exporting individual sequences to deliver for DVD Authoring from FCP to Quicktime (current settings). The quick-times occasionally have incorrect audio mix, more specifically keyframes to smoothly change audio level in FCP sequence are now much different in the quicktime, some levels actually pop on/off instead of faithfully reproduce as in FCP sequence. I’ve double checked the sequences and sound good. Not a consistent problem and happens occasionally.
    Any thoughts on what’s going on and what can I do to fix problem.
    Michael Harrington
    Mac Pro, Dual Quad-Core Intel Xeon 2.66 GHz, 12 GB, FCP7, Snow Leopard, ATI Radeon HD 4870, 30-inch Cine Display, 4 – 1TB internal, 1.25TB Esata, Numerous FW 800 external drives, MX02Max, FSI 17″ Broadcast Monitor, Mackie 1402 & Event 20/20 monitors.
    Michael Harrington replied 15 years, 10 months ago 1 Member · 1 Reply
  • Michael Harrington
    October 15, 2010 at 3:50 am
    I’ll give that a try, of course I render before I make quick-times although I have not done the mix down audio in quit a long time.
    Thanks for the tip.
    Michael Harrington
