Activity Forums Apple Final Cut Pro Legacy audio levels difference between QT and FCP
  • audio levels difference between QT and FCP
    Posted by John Hopkins on May 4, 2010 at 5:56 am
    I am noticing a significant drop on volume through my monitor speakers when I convert to a Quicktime from the timeline in FCP.
    How do I know what level the QuickTime audio is really is, and if it matches what I outputted from FCP. It sure does not sound the same, and I afraid it will not be broadcast at the intended level.
    Thanks for any help with this.
    John Hopkins replied 16 years, 4 months ago 1 Member · 1 Reply
  • John Hopkins
    May 4, 2010 at 8:09 pm
    I think I’ve resolved this. Seems the settings were at odds with each other from what I was outputting via Quicktime Conversion and the sequence settings. Now when I pull the QT back within a duplicated test Sequence as per the original it is no longer asking me if I want to match the sequence settings. As a result of duplicating all settings to mirror each other, presto the audio levels are where they should be on the QT ready to go to the broadcaster server. Hope this post might help someone else who had this difficulty.
