Activity Forums Adobe Audition Audio levels decrease when exporting
  • Audio levels decrease when exporting
    Posted by Adrian Smith on August 29, 2016 at 8:01 pm
    Hi, I’ve been having trouble with this. Everytime a export a multitrack mixdown, the new file’s audio levels are lowered even though the multitrack is exported with the same parameters as the original. Is there a way for my new exported file to have the same leves as the original?
    I’ll leave some screenshots to explain myself better:
    https://www.dropbox.com/sh/a2u7mtr9aj6qqqs/AABQvVPH6dVQXyxOT4m3mH2ca?dl=0
    Please help.
    Thank you for your time. I hope to hear from any kind soul soon.
    Steven Talley replied 9 years, 11 months ago 2 Members · 4 Replies
  • Steven Talley
    August 30, 2016 at 7:08 pm
    Have you tried altering the levels higher or lower and then check the output? If they come out similar to your -8 then their is limiting going on in the render stage.
  • Adrian Smith
    September 5, 2016 at 7:20 pm
    No, I didn’t alter anything in the audio file. I just exported it as a .wav file just like the original. Is it normal for the audio levels to lower when you export a file even if it has the same parameters as the original?
  • Adrian Smith
    September 5, 2016 at 7:52 pm
    Where do I check the output exactly?
  • Steven Talley
    September 14, 2016 at 5:30 am
    Sorry, I didn’t explain that well. I meant if you adjust the volume lower before rendering it out. Do you get similar results, as in a drop in the volume of the rendered file by a similar amount.
    If you render the file out at a higher volume, closer to 0db peak or above. What is the output level like from that. I’m curious if there is some limiting or compression being applied.
