Activity › Forums › Adobe Premiere Pro › Audio levels change back…after I adjusted them.
  • Audio levels change back…after I adjusted them.
    Posted by Matt Orfalea on June 7, 2014 at 5:50 am
    I adjust audio levels of clips in the timeline, and moments later I find the levels back to where they originally were. The program is essentially undoing my work.
    What can I do? I trashed the preferences but it’s back at it again.
    I’m using the latest version of Adobe Premiere Pro CC.
    Thanks in advance!
    Matt
    https://www.youtube.com/orf
    John Pale replied 12 years, 3 months ago 2 Members · 1 Reply
  • John Pale
    June 8, 2014 at 3:31 am
    Premiere has two audio mixers, one is track based and one is clip based.
    Is it possible you are adjusting the track based one by mistake and later on in the track undoing what you did (which will happen if you don’t keyframe)
    Use the clip mixer to adjust levels on individual clips
