Activity › Forums › Adobe Premiere Pro › Audio levels and Premiere-After Effects synamic link.
  • Audio levels and Premiere-After Effects synamic link.
    Posted by Paul Guarri on December 29, 2017 at 9:13 pm
    Hi, I have a sequence with some clips using dynamic links between premiere and after effects. The clips use both audio and video from after effects.
    My problem is, whatever setting I use, my audio is louder (and often clipping) after “Render and Replace”. This is also visible in the waveform. Any advice?
    Paul Guarri replied 8 years, 8 months ago 2 Members · 4 Replies
  • Jan Janowski
    December 30, 2017 at 1:12 pm
    Dave: You must Admit that what He (And You apparently Confirmed…) States is a problem, and he would appreciate a potential fix (Should one exist)…. Instead of a “Work Around”….
    No One likes to have to Remember: “Oh Yes, There’s a Bug in the Program….Don’t forget the work around….”
    I do this infrequently, but would also appreciate a fix, if one exists? I’d look at Default Audio Levels in both programs to see if they are both set the same…. For Example. PPRO Defaults at -12 (Instead of Broadcast -20)…. IF AE defualts to -20, there’s your 8Db of difference! But I’m not as good with AE….. So I’m guessing…
    Looking for 1939 Indian Motocycle
  • Jan Janowski
    December 30, 2017 at 10:50 pm
    Sorry— wrong attitude for a help forum….
  • Jan Janowski
    January 1, 2018 at 1:31 pm
    Don’t Apologize…… Help the fellow!!
    This isn’t a political soapbox, it’s supposed to be a Help Forum!!
  • Paul Guarri
    January 8, 2018 at 2:16 pm
    Thanks Dave and Jan.
    I’ve managed it sending the video only to AE and relying on the original audio from the clip.
