Activity Forums Apple Final Cut Pro Legacy Audio Levels and Pans Changing for no reason
  • Audio Levels and Pans Changing for no reason
    Posted by Kevin Waterson on May 17, 2011 at 10:55 am
    When we connect two large sequences together in FCP we experiance random changes in Audio Levels. The pans also change and left and Right levels are all screwed up.
    Does anyone else have this issue?
    Kevin
    Kevin Waterson replied 15 years, 3 months ago 2 Members · 2 Replies
  • Richard Cooper
    May 17, 2011 at 5:00 pm
    Hi Kevin,
    Are you by chance using nested sequences to combine your segments? I have always had weird audio stuff happen when I try to use nested sequences in FCP… So, I just never use them.
    If you are not doing this already, try combining your segments by copying and pasting one set of edits onto the other seq and see if this helps.
    Richard Cooper
    FrostLine Productions, LLC
    Anchorage, Alaska
    http://www.frostlineproductions.com
  • Kevin Waterson
    May 18, 2011 at 6:50 am
    Thanks for this.
    We do have small nested sections of video but we never nest audio with them.
