Activity Forums AJA Video Systems Audio Level Hot
  • Audio Level Hot
    Posted by Eddie Kesler on August 18, 2010 at 2:50 pm
    I have an AJA io HD and the audio level coming out of Final Cut into the io is too hot. When I play out the Final Cut Bars and Tone without any adjustments to the level (-12), it’s playing back with some distortion and it shows two yellow bars on the meters on the io. I adjusted the audio playback level from +24 to +12 on the AJA control panel. It lowers the volume, but not on the meters.
    How can I get it calibrated properly?
    Eddie
    https://www.jamedit.com
    Jeremy Garchow replied 16 years, 1 month ago 2 Members · 1 Reply
  • Jeremy Garchow
    August 18, 2010 at 5:15 pm
    Tone should be set to -20. -12 is a hold over from dv days and FCP has never been updated.
