Activity Forums Compression Techniques audio level check with ffmpeg
  • audio level check with ffmpeg
    Posted by Jay Gustafson on January 27, 2012 at 5:23 pm
    I’m looking to write a script that will check the audio mic level of my mpeg recordings. If there a way to have ffmpeg report the audio level (in dB for example)on a frame-by-frame basis so my script can verify the audio level?
    Michael Rampe replied 14 years, 7 months ago 2 Members · 1 Reply
  • Michael Rampe
    January 30, 2012 at 10:19 pm
    I use SoX for this operation.
    https://sox.sourceforge.net/
    A command like:
    $ sox $INPUT -n stats 2> stats.txt
    …will give you a lot of useful data. I found that you get quite inaccurate results on some recordings due to subsonic non-vocal frequencies.
    You can also use SoX to filter these out such as:
    $ sox $INPUT -n -D highpass 100 stats 2> stats.txt
    Let me know if this helps.
    Michael
