Activity Forums Avid Media Composer audio level adjustment
  • audio level adjustment
    Posted by Themis Gyparis on September 20, 2008 at 8:17 am
    Hi everybody
    Assuming I have added a music track on channels A1 and A2 and several parts of a narration track on A3 an A4. If I add keyframes to my music tracks accordingly, in order for the music to rise and drop in between narration in and out points, is there a way to adjust music volume for all of these spaces in between (i.e. only for the parts that the music level would drop)? I’m guessing it has to do with in and out points, but I believe this would also affect the parts that I don’t want to adjust. Right? Any suggestions?
    Thanks a lot in advance
    Themis Gyparis
    Happy Trimmmer Production and Post Production Studio
    Steve Pankow replied 17 years, 11 months ago 3 Members · 2 Replies
  • Jon Zanone
    September 20, 2008 at 1:18 pm
    Adding an in/out will allow you to adjust all the keyframes in the selected track(s). If you have your music ducking under narration, it’s probably best to do that individually.
    Jon
    “Jamming our heads full of figures and angles
    And telling us stuff that we already know”
    Willie The Wandering Gypsy & Me
    Billy Joe Shaver
  • Steve Pankow
    September 20, 2008 at 9:06 pm
    A thought would be to throw in add edits to the areas you want to lower and move those sections down to new audio track(s) using the segment tool.
    Then highlight the entire new audio track(s) and adjust one section to the new lower level, making sure you have the “apply levels to in/out” (or whatever it’s called) on.
    Once that’s set, move the sections back up into the original positions on your original audio track(s) and apply dissolves to all in/out points.
