Activity › Forums › Adobe After Effects Expressions › Audio Layer Confusion
  • Audio Layer Confusion
    Posted by Darby Edelen on March 6, 2008 at 11:28 pm
    Alright, this isn’t making any sense to me… I have this expression applied to an audio layer’s audio levels:
    l = thisComp.layer("Flash").transform.opacity.smooth(.2, 3);
    x = linear(l, 0, 100, -72, 10);
    [x,x];
    And the dB appear to change correctly when i scrub through the timeline, but whenever I preview the composition the audio plays back at a steady 0dB. When I remove the expression I can keyframe the dB and it works properly, but this expression seems to be causing trouble.
    Is there something obvious I missed in writing this out?!
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
    Lloyd Alvarez replied 18 years, 6 months ago 3 Members · 5 Replies
  • Dan Ebberts
    March 7, 2008 at 12:04 am
    It’s a mystery to me. If you look at the graph, it appears to be working, but it doesn’t show up in ram or audio preview. Strange.
    Dan
  • Darby Edelen
    March 7, 2008 at 1:01 am
    [Dan Ebberts] “If you look at the graph, it appears to be working, but it doesn’t show up in ram or audio preview. Strange. “
    So you were able to recreate the problem? I thought maybe something had become corrupted in my project, because it was working earlier with a different audio file, but if it’s not working for you then I’ve lost all hope =O
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Dan Ebberts
    March 7, 2008 at 1:16 am
    I did repro it. And I could swear I’ve done stuff like this before. But….. it works in AE 7. Apparently something happened in CS3.
    Dan
  • Darby Edelen
    March 7, 2008 at 1:21 am
    Apparently applying Time Remapping to the layer fixed the problem… and I have no idea why. I didn’t change any of the time remap values, just applied it to the layer and presto: back in business.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Lloyd Alvarez
    March 11, 2008 at 10:57 pm
    Make sure you file a bug so the AE team is aware of the problem and queue’s it to be fixed.
    https://www.adobe.com/go/wish
    -Lloyd
    https://aescripts.com
