Activity Forums Apple Final Cut Pro Legacy Audio Latency Issue
  • Audio Latency Issue
    Posted by Decloux on February 20, 2007 at 9:11 pm
    Hey folks.
    This is my first post since getting this system last month.
    Thanks in advance for any help.
    Capturing via firewire400 from canon XL1.
    Approx one hour in a single take (DV NTSC capture)
    Quicktime Capture File itself appears out of sync.
    Put into a DV NTSC timeline.
    OK so I still have a sync prob in the timeline.
    Frame Offset seems not to effectively solve the problem.
    (AUDIO FOLLOWS VIDEO is always grayed-out)
    By breaking the linkage in timeline,
    and then making the video match by moving the audio tracks to the right
    (eyeballing the lip-synch) I measured the following shift:
    Audio starts out 27 frames ahead of video.
    At 30 minutes in, it is about 19 frames ahead.
    By the end of the hour it is only 7 frames ahead.
    There are some pauses in the tape, not sure about extent
    of any timecode breakage on the tape.
    So Today
    I made a test segment using the same camera and using
    a tape from that same day of shooting (project shot way back in 1998).
    Segment created today consisted of clapping a pencil for 15sec.
    Imported same method into same timeline.
    Result: Zero Latency in timeline.
    According to timeline waveforms it’s a near perfect match.
    (Offset set to the default of 4)
    What’s going on? Is a 1-hour Capture just too long?
    From what I see, changing Capture Offset wouldn’t fix a moving target like this.
    Am I being punished for having six memory slots filled (instead of 4 or 8) ?
    FCP 5.1.3
    MacPro 2.66
    5Gb Ram (4x1Gb OWC + original 512×2)
    2x500Gb drives
    Monitoring via Built-In Line-out to self-powered speakers.
    Same result using Built-In Speaker and Headphone (on every test).
    Capture Scratch and project on nearly empty new Maxtor 500Gb drive
    (not system drive)
    Decloux replied 19 years, 7 months ago 2 Members · 4 Replies
  • David Battistella
    February 20, 2007 at 9:50 pm
    Try this,
    capture it in ten minute increments and then stich it together in the timeline. I still never capture more than ten miutes of media to a single clip, EVER! A sixty minute tape is logged and goes in ten minutes at a time.
    David
    Peace and Love 🙂
  • Decloux
    February 20, 2007 at 10:19 pm
    David
    Thanks much for the quick response
    OK –
    I will give it a shot.
    Please stay tuned to this freq, er thread – I will be back with results.
    I suppose I will batch it, so it will be a couple of hours at least.
  • David Battistella
    February 20, 2007 at 10:37 pm
    Try this,
    David
    Peace and Love 🙂
  • Decloux
    February 21, 2007 at 3:35 pm
    David –
    Thanks for the help.
    OK I’ve batched the entire 2-1/2 hours in 10-minute segments, and it seems that this clears up the latency issue.
    This is something of a relief, but I have to admit
    it’s a bit disappointing that even with “regular” DV I
    may not be able to capture larger chunks.
    If I come up with a better solution I’ll post results.
    – decloux
    “Try this, capture it in ten minute increments and then stich it together in the timeline. I still never capture more than ten miutes of media to a single clip, EVER! A sixty minute tape is logged and goes in ten minutes at a time.”
