Activity › Forums › Apple Final Cut Pro Legacy › Audio lags behind video
  • Audio lags behind video
    Posted by Lawrence Eaton on January 15, 2010 at 3:18 pm
    I have an AVI that I’ve pulled into FCP and it would appear that the audio is lagging behind the video track by about 3 seconds (based off what I’m hearing and seeing in the waveforms).
    Is this normal?
    can it be cured by rendering it out first?
    Always regard you all as saviours; be it mental or work wise…
    Lawrence Eaton
    Todd Gillespie replied 16 years, 8 months ago 2 Members · 1 Reply
  • Todd Gillespie
    January 16, 2010 at 9:25 pm
    It’s always best to convert footage to QuickTime if you plan on editing with it. It will render faster and work better than leaving it in AVI.
    Sync can also be a problem when you’re drives are too full.
    Good Luck,
    Todd at UCSB
    Television Production
