Activity Forums Adobe After Effects audio keyframes
  • audio keyframes
    Posted by Mcmohawk on April 17, 2007 at 2:04 pm
    if anyone could help with this id appreciate it.
    im trying to link the opacity of a layer to some audio. im using the convert audio to keyframes, however, when the opacity is linked to it, it only ranges from 5 to 10 percent. what do i need to add to the expression to increase the range? im using AFX 7.
    cheers
    Curious Turtle replied 19 years, 5 months ago 3 Members · 2 Replies
  • Dan Blaim
    April 17, 2007 at 2:12 pm
    Go into the expressions scripting box and add *2 to multiply the effect by 2. experiment with other numbers, *5 for 5 times the opacity range or *.5 for half the range.
  • Curious Turtle
    April 17, 2007 at 2:15 pm
    The simplest way would be just to multiply it by 10. Simply add “*10” at the end of your expression should work fine.
    If you want to get a bit more complicated then you could use another interpolation expression command, like Linear(). You can find a good explanation here .
    Good luck,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
