Activity Forums Apple Final Cut Pro Legacy audio keyframes + capture settings
  • Shane Ross
    January 30, 2007 at 11:08 pm
    Yes, stereo capturing would have allowed for you to keyframe both. BUT, you still can. Highlight both audio tracks and hit OPT-L. This will make them a stereo pair.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Quentin Block
    January 31, 2007 at 2:30 am
    Thanks, Shane. I am so glad that you responded to my post. After 5 days I had just about given up hope.
    I’ll try your suggestion.
    BTW, Is there any way to copy keyframes from one track to another, so I can duplicate the work that I’ve already done (on one track)?
    Cheers!
  • Shane Ross
    January 31, 2007 at 3:02 am
    Sorry…I don’t check this forum as much as I should.
    Yes..highlight the track and hit APPLE-C. Highlight the other track and hit OPT-V…choose LEVELS.
    Or…if you make them a stereo pair, the levels should automatically transfer.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Quentin Block
    January 31, 2007 at 11:57 pm
    Thanks again, Shane!
