Activity Forums Apple Final Cut Pro Legacy Audio keyframes
  • Audio keyframes
    Posted by Dylan Etherington on June 15, 2008 at 5:24 pm
    Good Afternoon.
    I have been editing a piece together to music and when I add a keyframe to either the left or right track of the song (tracks 3&4), it adds another keyframe in the same place on the other track. That is good, however when I add a keyframe to either track 1 or 2 which is the audio attached to the clip, this does not happen and I have to add another on the other track and match it up. How do I change this so as track 1&2 are the same as track 3&4?
    Cheers.
    Jess George replied 18 years, 3 months ago 2 Members · 1 Reply
  • Jess George
    June 18, 2008 at 9:31 pm
    You’ve probably figured this out already, I hope, but your issue is that you have to pair the tracks. Select the two tracks and hit Option+L.
    Good luck!
    Jess
