Audio Keyframe issues going from Premiere CS 5.5 to Audition
I can’t seem to find any other comments about this, but I can’t imagine I’m the only one as it’s happening with all of my projects.
I’ve done volume adjustments in Premiere using keyframes, but I wanted to mix in Audition. Every time I send the sequence to Audition, my keyframes move backwards on all my volume adjustments. At first it looked like they weren’t even there, but extending the handles on one of the clips showed they were offset by a second or two.
Has anyone else had this problem? Any fixes other than having to just redo it in Audition?
-Colin Brooker
