Activity Forums Apple Final Cut Pro Audio keyframe
  • Audio keyframe
    Posted by Michael Sanders on December 30, 2013 at 10:22 am
    This is pretty cool – not sure if pre 10.1 did this but..
    In an audio track, create to key frames. Put the cursor between the two keyframes – the cursor becomes the weird cross hairs. Hold down the mouse key and drag left or right.
    That’s neat!
    Michael Sanders
    London Based DP/Editor
    Bret Williams replied 12 years, 8 months ago 5 Members · 4 Replies
  • Mark Dobson
    December 30, 2013 at 10:28 am
    [Michael Sanders] “In an audio track, create to key frames. Put the cursor between the two keyframes – the cursor becomes the weird cross hairs. Hold down the mouse key and drag left or right.”
    Or up and down – yes, this can save a lot of time, pretty neat.
  • Don Smith
    December 30, 2013 at 12:12 pm
    Michael – Great tip! I had wondered about the four-direction indicator but the tutorials I watched made no mention of it. Thank you.
    Don Smith
    NewsVideo.com
  • Dave Jenkins
    December 30, 2013 at 5:42 pm
    Great tip, will speed things up!
    Dajen Productions, Santa Barbara, CA
    MacPro 3.2GHz Quad Core – AJA Kona LHe+
    FCS 3 OS X 10.7.4
    FCP X, Logic Pro, Squeeze, Filemaker 10.8.3
  • Bret Williams
    December 30, 2013 at 7:04 pm
    Use the range tool to select multiple keyframes to drag or to copy and paste. All new 10.1. Works on all types of keyframes.
