Activity Forums VEGAS Pro Audio Key Framing in Vegas
  • Audio Key Framing in Vegas
    Posted by Dan Eggleston on November 3, 2007 at 8:13 pm
    One more question and I promise to take a break…
    One of the things that has bothered me working with Vegas 5.0 is audio key framing. I use Avid Xpress Pro at work and I can key frame audio within individual clips. If I move the clip the audio key frames stay, as they are part of the clip.
    From what I’ve experienced with Vegas 5.0 is when I key frame audio the key frames are placed above the clip and is part of the whole track. If I need to slide the clip the key frames don’t follow. This can be a major pain.
    Of course it could be operator ignorance and there may be a way to key frame audio from within individual clips. However, from a screen shot I saw of Vegas 8, it looks like the audio key framing is the same. Can anyone explain a way to key frame audio and have it embedded in a clip rather than on a track globally (so to speak)?
    Rick Mac replied 18 years, 10 months ago 2 Members · 3 Replies
  • Rick Mac
    November 3, 2007 at 8:56 pm
    If you want keyframes to move when you move an event on the
    timeline, choose “lock envelopes to events” found under the options menu.
    Regards, Rick.
    Rick Mac
    Director of Audio Production
    TCT Network – Directv 377
  • Dan Eggleston
    November 4, 2007 at 1:38 am
    Thanks Rick. I wish I would have asked this question years ago! Does it work if you move the event to a different track, or only along the same track?
    Dan
  • Rick Mac
    November 4, 2007 at 5:54 pm
    [Dan Eggleston] “Does it work if you move the event to a different track, or only along the same track?”
    Yes it will move them to the new track.
    Regards, Rick.
    Rick Mac
