Activity › Forums › Blackmagic Design › Audio Issues with Declink / FCP system
  • Audio Issues with Declink / FCP system
    Posted by Chris1234 on June 16, 2006 at 4:29 pm
    Recently installed a new edit suite with G5 system (10.4.6 OSX — Quad G5 2.5 Gb RAM)
    and Black Magic Decklink Extreme PCI Card;
    All updated drivers and Quicktime 7.1.
    Problem is after capture, analog audio from the card output disappears when trying to playback. By switching the AV playback from 8 bit NTSC (we use 8 bit NTSC – 720×486) to 10 bit NTSC and back again, audio reappears, but disappears once another capture is preformed.
    Any Ideas?
    Kristian Lam replied 20 years, 3 months ago 2 Members · 1 Reply
  • Kristian Lam
    June 17, 2006 at 2:43 am
    Hi Chris,
    Is your easy setup (Final Cut Pro > Easy Setup) set up “Blackmagic NTSC – 8 bit”?
    regards
    Kristian Lam
    Blackmagic Design
