Activity Forums VEGAS Pro audio issue vegas 9
  • audio issue vegas 9
    Posted by Martin Phillips on November 18, 2009 at 2:52 pm
    I have just started editing a wedding ceremony, and have noticed for the first time a strange occurrence with the audio captured on channel 2 (lapel mic on the groom). Whilst someone is speaking the audio is fine, but in between words or sentences the audio drops to silent…. i have opened another finished wedding and found this doesn’t happen… it is almost as if a noise reduction filter has been applied, and it is very noticeable… can anyone throw any light on this problem.
    Regards
    Martin
    Martin Phillips replied 16 years, 9 months ago 3 Members · 3 Replies
  • John Rofrano
    November 18, 2009 at 6:19 pm
    See if the Noise Gate is turned on in the Track FX. Each audio track has a Noise Gate, Track EQ, and Track Compressor applied by default. It sounds like the Noise Gate made have has the Threshold raised and is kicking in. Just turn it off or remove it.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Charles Avanti
    November 19, 2009 at 1:41 am
    you probably recorded it with the camera AGC on.
    Charlie
  • Martin Phillips
    November 19, 2009 at 7:25 am
    I checked the camera settings (I’ve used this camera for 2 years same settings) I can’t get it to repeat the problem at camera. I’m going to try jonhs tip today. Thanks for your response. Martin
