Activity › Forums › Compression Techniques › Audio issue on compression output
  • Audio issue on compression output
    Posted by Sam Waldron on May 29, 2011 at 10:20 pm
    Hi there,
    I have put together a small 2 min sequence using sped up footage to 500-600%.
    Long story short. When I export this sequence the audio is also sped up. When playing the sequence in Final Cut Pro the speed has not been sped up and sounds normal.
    Has this got something to do with interlacing as the audio is the original recorded from the camera?
    Any fixes or work a rounds?
    Thanks in advance
    Sam
    Sam Waldron
    Final Cut Pro 6.0.6
    imac 4gb 1tb
    Sam Waldron replied 15 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
