Activity Forums JVC Cameras Audio Issue JVC HM100U – 2 mics?
  • Audio Issue JVC HM100U – 2 mics?
    Posted by Niya Shah on May 29, 2011 at 8:10 pm
    Hello, apologies if this is a newbie question…
    I recently purchased a wireless lav mic as I will be shooting interviews in the field. When I plug in the mic/transmitter, all of a sudden I can’t use my boom mic – am I missing something?
    I tried playing around with the switches, to be honest I would love a primer on how the channel 1 and channel 2 work, anyone point me in a good direction so I can school myself on this?
    In the meantime, I would appreciate any help in getting both mics to work…
    Cheers,
    Niya
    Jeffrey Carter replied 15 years, 3 months ago 2 Members · 5 Replies
  • Jeffrey Carter
    June 2, 2011 at 12:52 am
    You can plug the camera mic in one channel, and the wireless in another – then be sure to set CH 2 input to CH 2 not CH 1. This is the left most switch on the audio panel (where the XLR jacks are). Also make sure phantom power is set to ‘on’ on the channel that the camera mic is plugged into.
    Now you will have two separate channels of audio, one for each mic.
  • Niya Shah
    June 3, 2011 at 12:44 am
    Thanks so the problem is that the wireless mic goes into a small plug on the main camera body above the headphone jack. When this wireless mic is plugged in, my manual says I have to remove the audio in cable from the audio in terminal – this cable is what connects channel 1/channel to the camera. It seems I can’t do both at once for some reason…I was looking into buying a cable adapter that has a male xlr and 3.5mm in order to use the channel inputs and just not use the 3.5 mic input.
    This is reference to the JVC HM100u – hope this makes sense….anyone have this problem?
  • Jeffrey Carter
    June 3, 2011 at 1:07 am
    I was assuming you were using the handle which has XLR jacks. This gives you much more control over audio.
  • Niya Shah
    June 3, 2011 at 1:15 am
    That is exactly what I want to use…however my wireless lav set did not come with xlr inputs – so sounds like I need to buy an adapter that has 3.5mm to male xlr pin…
  • Jeffrey Carter
    June 3, 2011 at 12:41 pm
    That would be best. A lot of newer mic sets have stereo 1/8″ jacks for balanced audio out, using a stereo 1/8 to XLR cable.
