Activity › Forums › Boris FX Sapphire › Audio Issue – Corruption of sound upon rendering
  • Audio Issue – Corruption of sound upon rendering
    Posted by Gary Meade on August 5, 2009 at 7:55 pm
    I downloaded the trial version of GenArts Sapphire (v 2.02) and used it for the duration of the 30 day trial period without many problems apart from the odd frame here and there being out of place which was reported as normal for an older version. However when the trial expired, I’m having all kinds of audio issues, with sounds fuzzing every now and then especially when I put a sequence in another sequence.
    I’ve since removed Sapphire but the problems are still apparant, I even get odd frames added in here and there and random pieces of audio played (especially on crossfades between sequences).
    Has anyone got an idea why this is happening or how I can completely remove sapphire? I’ve reinstalled the CS4 suite but to no avail…
    Cheers!
    G.
    Gary Oberbrunner replied 17 years, 1 month ago 2 Members · 1 Reply
  • Gary Oberbrunner
    August 6, 2009 at 1:21 pm
    Hi Gary; you should be able to remove Sapphire with the uninstaller. On Windows use Control Panel -> Add/Remove Programs, on Mac go to /Applications/GenArtsSapphireAE and double-click Uninstall Sapphire.
    That said, I have never heard of any video plug-in corrupting audio. The plug-ins don’t even have access to the audio tracks. Are you sure you don’t have some other corruption on your system? Your mention of “frames out of place” also sounds suspiciously like disk corruption; no version of Sapphire should do that.
    — Gary
