Activity › Forums › VEGAS Pro › Audio issue
  • Audio issue
    Posted by Zach Hardison on March 8, 2011 at 4:22 am
    A couple issues I’m running into…
    When I load an avi file into Vegas and play it, the audio isn’t coming through at all, but does with any other file I’m using. Is there a codec or plugin I’m missing?
    I’ve tried converting the avi to another file type, which works, but the quality of the video is then severely lowered.
    Any ideas?
    Mike Kujbida replied 15 years, 6 months ago 3 Members · 2 Replies
  • John Rofrano
    March 8, 2011 at 2:23 pm
    [Zach Hardison] “When I load an avi file into Vegas and play it, the audio isn’t coming through at all, but does with any other file I’m using. Is there a codec or plugin I’m missing?”
    Yes, that’s usually a codec problem. You can use a free utility called GSpot that will tell you what codec a file uses and if it is installed or not. Here is a sample to help you interpret what GSpot is telling you:
    Find the codec that you need and install it. DO NOT install a codec-pak like K-lite to try and solve this. If you only need one codec, just install that codec.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Mike Kujbida
    March 8, 2011 at 2:33 pm
    Where did the AVI file come from?
    Camcorder, digital still camera, etc.?
