Activity › Forums › VEGAS Pro › Audio issue
  • Audio issue
    Posted by Chrisabel Noyes on June 26, 2011 at 2:19 pm
    Hey,
    I was wondering if you could help? I use sony vegas pro 9.0c (64bit), running on windows 7 (64bit system). I’ve been using this program for a long time with no problems, up until today, when i tried to import certain avi files (which are xvid, tv downloads) onto the timeline, it shows only ‘video’ not the ‘audio’. I know this is a problem with vegas, regarding codec issues, that sony doesn’t support, as i had this problem back with sony vegas 8. I’ve used gspot etc, and all the codec are installed. What i don’t understand is that it has been working up until now, so there should be no codec issue? And i haven’t installed anything, or deleted anything. Any chance you might no why this could be?
    Any help would be great!
    John Rofrano replied 15 years, 2 months ago 2 Members · 5 Replies
  • John Rofrano
    June 26, 2011 at 3:46 pm
    I assume you already know that Xvid and DivX are not supported by Vegas. If you are using a 64-bit version of Vegas you would need a 64-bit Xvid codec.
    Anyway the solution is to not use Xvid or DivX so just convert the files with something like AviDemux to a format like Motion-JPEG video with PCM audio and the files should edit fine.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Chrisabel Noyes
    June 26, 2011 at 4:39 pm
    Thanks for the info, am downloading AviDemux now!
  • John Rofrano
    June 26, 2011 at 8:28 pm
    You can try these settings once you have it installed:
    ~jr
  • Chrisabel Noyes
    June 26, 2011 at 9:26 pm
    Am a bit confused, i used the setting that you’ve given me (thank you for that) and set the markers a/b, but how do i save it? Probably something obvious that am missing!
  • John Rofrano
    July 3, 2011 at 5:25 pm
    [chrisabel noyes] “Am a bit confused, i used the setting that you’ve given me (thank you for that) and set the markers a/b, but how do i save it? “
    The Save Video button is the second icon from the left on the toolbar (the diskette).
    ~jr
