Activity Forums Apple Final Cut Pro Legacy Audio is slightly compressed and distorted when played in FCP
  • Audio is slightly compressed and distorted when played in FCP
    Posted by Dan Crouch on March 23, 2012 at 1:41 pm
    Please can anyone help with this?
    I am cutting a sequence for a DVD using very old Pathe archive footage.
    When I play the Qt’s on from my desktop they have a lovely warm distortion to them, but when they are imported and played on the timeline, the warm distortion is quite grating. It is a very subtle difference but it goes from being nostalgic and ‘old’ sounding to being quite uncomfortable on the ears.
    Please can anyone help with this? I’m not too good with import setting etc but could it be a frequency conversion issue or something similar?
    Thankyou in advance,
    Dan.
    Dan Crouch replied 14 years, 5 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    March 23, 2012 at 6:24 pm
    What video format is the source footage? FWIW, you really can’t accurately judge picture without sending the signal out to a video monitor…
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Dan Crouch
    March 23, 2012 at 7:05 pm
    Thanks for the post’s guys. I could take it into soundtrack pro and improve it, I just don’t know why it is playing back with a different tone. Does FCP automatically compress the signal or something?
    Dan.
  • Michael Gissing
    March 24, 2012 at 1:04 am
    What are the codec settings for picture & sound for these QT files?
  • Dan Crouch
    March 31, 2012 at 7:54 am
    Thanks for the posts’s.
    It took a while to reply as I had to order a new copy of Snow Leopard to get QT 7, In order to get the pro version, to get full audio info.
    The original Pathe archive clips, has audio that is running at 48 KHZ,
    This is the same as my FCP project.
    DV, 720 x 576 (768 x 576), Millions
    16-bit Integer (Little Endian), Stereo, 48.000 kHz
    Data rate is 30.34 mbits/s.
    I did a test on Avid, importing the same clip and there was no difference in sound quality whatsoever. Therefore FCP is changing the sound somehow…
    Any help would be very much appreciated. The director owns a record company, he’s got super man hearing, so audio is very important.
    Thanks very much.
    Dan.
