Activity › Forums › Apple Final Cut Pro Legacy › Audio is offline after source move
Posted by Michael Nichols on September 3, 2008 at 2:48 amHelp!
I have a project that has merged clips. I moved the source audio files to another drive. I reconnected the media in the bin (the original files, not the master files) but I can’t seem to reconnect the offline media in the timeline from the merged clips.
Any clues?
Manuela Lupini replied 15 years, 4 months ago 4 Members · 4 Replies -
Jerry Hofmann
September 3, 2008 at 4:13 pmI think in order to get merged clips to move without hitches you have to use the Media Manager for the moving… if you drag and drop them, they likely won’t reconnect properly.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
Michael Nichols
September 4, 2008 at 2:19 amThanks Jerry! Always to the rescue…
On that note, I have figured out a work-around that might actually speed things up a bit. Question though: Shot in the dark here, but is there a way to batch rename source files? I ask, because my sound recordist gave me all the sound files with the source names of “recording.mov, recording1.mov” etc. I have renamed all the recordings in FCP, but if there was a way to match the source name with the file name in FCP, I can save myself a boat load of head aches.
Thanks in advance!
Ivana Rogić
March 22, 2009 at 10:56 amHI! I have a problem!I worked at home,merged clips video and audio(wav) and when I brought it back to work and try to reconnect it,the video reconnected ok, but the audio didn’t.The in points on wav files were ok,but the merged clips were like 15 hours long! I tried usig media manager but the FC couldn’t copy my files.Does enyone have anothher solution?
Manuela Lupini
April 28, 2011 at 1:56 amHello Jerry!
I’m a rookie at Media Management in FCP. I used the Media Manager to move sequences with merged clips from one drive to the other. The problem is that when I reconnected the media: all the audio clips have changed their name to the VIDEO file that was linked to them. Is there a way to change them back to their original name? (in order to be able to work with the sound tracks separately)
Any suggestions are welcome,
Thank you so much for your time!!!Manuela
