Activity › Forums › Blackmagic Design › Audio is not recording in 6.2 driver verison
  • Audio is not recording in 6.2 driver verison
    Posted by Jekabs on June 18, 2007 at 2:07 pm
    Hello.
    I am worknig on
    Intel Xeon Quad Core 2×3 GhZ
    6 GB of RAM
    Blackmagic Multibridge Extreme
    Dirver version 6.2.
    FCS2
    I’ve tryed to capture a material from XDCAM thru sdi input and analog xlr audio input. when i press play in the capture window audio works fine, when i press “capture clip” and after capture try to playback it in final cut, there is no audio in the waveform.
    i reininstaled the drivers to 6.1 and now it works fine. the audio captures.
    Jekabs
    Sebastian Hampl replied 19 years, 3 months ago 3 Members · 2 Replies
  • Dan Sparks
    June 18, 2007 at 4:26 pm
    I had a similar problem and traced it down to the Sound Preferences pane in the System Preferences being reset by the 6.2 installer. I had to set in back to Decklink Audio in.
    Dan Sparks
    Tricom Video
  • Sebastian Hampl
    June 18, 2007 at 6:50 pm
    Same here! I also had to change the audio preferences in the capture easy setup bach to Decklink Audio. That solved the problem.
    All the best
    Sebastian
