Activity Forums Apple Final Cut Pro Legacy Audio is distorting when I play the sequence.
  • Audio is distorting when I play the sequence.
    Posted by Eric Hammond on July 14, 2009 at 8:45 pm
    My audio on my timeline is clean, but occasionally when I hit play on the timeline it starts to distort. I’ll push the space bar a few times and it eventually plays clean. This is very annoying and it’s driving me crazy! Of course it almost always happens when I print to tape. Does anyone have any ideas? Thanks for your help.
    Eric
    Eric Hammond replied 17 years, 2 months ago 2 Members · 6 Replies
  • John Fishback
    July 15, 2009 at 1:42 pm
    Give us your system and software specs. What computer, version OS, i/o card or device, how you’re monitoring audio and video, drive setup & speed, version FCP, etc.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Eric Hammond
    July 15, 2009 at 2:42 pm
    Thanks for your help. This is what I have:
    MacPro 10.4.11 2×3 GHz 8GB 667 MHz
    ATI Radeon x1900 xt
    vram (total) 512 mb
    Blackmagic Multi Bridge Pro
    2 Dell monitors (don’t ask me why)
    Flanders Scientific 17″ preview monitor
    Final Cut Studio 2
    Any suggestions about getting new stuff would be great.
    Eric
  • John Fishback
    July 15, 2009 at 2:47 pm
    How are you monitoring your audio? Do you have a mixer?
    John
  • Eric Hammond
    July 15, 2009 at 3:00 pm
    Oh yeah. I have a Alesis Multimix 8, It takes the feed from the multi-bridge. And runs to KRK rokit5 speakers.
    Eric
  • John Fishback
    July 15, 2009 at 6:30 pm
    I’m wondering if there might be a ref problem between the Multi Bridge Pro and the mixer. Are you using digital audio connections(aes or spdif) or analog. I’m not familiar with the details of that mixer. Does it need a ref signal or word clock. If the audio isn’t synced properly that could be a reason. You might try disconnecting the mixer and running the output of the Multi Bridge directly to the speakers. Just be sure to lower the gain so you’re not combing speaker parts from your hair.
    You should do an Audio Mixdown if you haven’t: Sequence Menu > Render Only > Mixdown. A while back I had some weird audio play issues so I trashed prefs, repaired permissions and ran Disk Warrior. I haven’t had an audio wierdness since.
    John
  • Eric Hammond
    July 16, 2009 at 3:31 pm
    Thanks for your help John. I’ll give that a try.
    Eric
